Hello!
I had a hard drive failure on the machine I use MicroStation on, and after a reinstall of the operating system, etc on a new drive I reinstalled Microstation. However, I was using a checked out license against a SELECTServer prior to the harddrive failure, now Microstation still thinks it is checked out on this machine, as naturally I would not have checked it back in.
What are my options here to get this recovered? I am currently working on trial version due to this.
Thanks.
You can recover the checked out license via the SELECTserver Administration page if you have access. If you do not have access your site administrator should. Wiki below has more information.https://communities.bentley.com/products/licensing/w/licensing__wiki/2781/viewing-and-checking-in-licenses-using-the-site-administration-page-tn
