1- can I add files directly from PW into the Project Share?
2- can cad files in the project share be used as xref's for CAD files in PW?
thanks,
Kirk
Hello Kirk,
You can only upload and download files from Project Share. At this time you can't link files to/from ProjectWise or use them as xref's. See: https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/33706/share
Tamicca SellarsProduct Manager I
Answer Verified By: Kirk Peterson
Tamica - thanks...and that stinks. So this is basically FTP on the Bentley CONNECT site?
Are there plans to directly link it with PW? It would be much more useful if it did.
At the very least, is there a way to have it notify another person if a file is uploaded?
Hi Kirk,
Unknown said:So this is basically FTP on the Bentley CONNECT site?
I'm not sure how FTP works, but you can upload/download files of all type and pick who has access to those files/folders through Role-Based Access Control.
Unknown said:Are there plans to directly link it with PW?
Not at this time, but I don't want to say it will never happen because it's possible. I think Project Synchronization could be an option for you. Here's a link to the Help Contents
Unknown said:is there a way to have it notify another person if a file is uploaded?
Not at the moment. We're working on it, but I don't have an ETA.
Hello Zach,
Which application are you using and where did you post your question?
