I've noticed that when a user goes to the Software Download Center that the CONNECT edition is ON by default. This is very annoying as many of your tools are not available in CONNECT and we need to continually turn it off.
I'd suggest you turn that OFF by default as if I want a product AND it has a CONNECT edition available, it will show up when I look for the title.
Hello Shawn,
The CONNECT Edition filter is on to ensure that you get the most up to date software. If the application you want doesn't have a CONNECT Edtion you can turn off the filter as you mentioned.
Thank you for your suggestion.
Tamicca SellarsProduct Manager I
