A Semi-Government organization is standardised on v8i platform. The team likes all the new features in MicroStation CONNECT except its ability to allow a user to publish and share files via Bentley Portal, as it is goes against their security policy. What are the different options available to block a MicroStationCONNECT user from publishing to Bentley Portal and and sharing the data?
Please create a service request for this. https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/30277/support-contact-information
Tamicca SellarsMicroStation Product Manager
Answer Verified By: Rizwaan Ansari
So what was the answer to this?
To file a service request to have it done.
Thanks. I have raised the request.
Tamicca Sellars it would be useful if this type of feature (ie disablement of / or ability to selectively enable / disable) some of the connect features was able to be administered from an enterprise management portal. This would extend to being able to select which projects are potentially exposed to mobile capabilities and even to a role / user level.
