I need some assistance with the BCC silent installation. The instructions are about as clear as concrete. I have sent in a service request but never receieved a response (dont I pay for that?)
The instructions say to install the CC. I did on my local machine. Then it says at the command line to enter the commands followed by the 2 or three digit code on the install. What? My install file has a long string of characters that dont match the example. Am I to deploy this on the server? Do I open up a command prompt for the silent install?
This is a poorly implemented set of instructions in my opinion. Can someone please assist?
The command prompt mentioned is the Windows Command Prompt that you open to run command lines https://www.lifewire.com/how-to-open-command-prompt-2618089. Those instructions are for pushing out the silent install that way. In your case you have already installed it manually so the installation is complete. You can create a deployment image and place it in a shared folder on your network and have your users install that way. Here are instructions on how to create a deployment image: https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/37164/how-to-create-a-deployment-image
Tamicca SellarsProduct Manager I
Tamicca,
Thank you for the asssitance. Why is this not included in the instructions that I was provided? https://www.bentley.com/en/perspectives-and-viewpoints/topics/campaign/bentley-user-registration?BPID=chaz@wrtoole.com&CEID=CT_EMAILB_OPRDS_SLT_1116&et_cid=3006940&et_rid=44246238&et_cc=&et_lc=English&SKID=CT_EMAILB_OPRDS_SLT_1116
Hi Charles,
The wiki was written after the site was up and running so it couldn't be included.
This is an extremely confusing instruction set, at least for me. The instruction guide (PDF) has a completely different set of instructions. Deployment is accomplished by using command prompt commands on the original executable. The deployed file names per your recent unstructions are different.
So far I have:
BULK REGISTERED the users.
The (PDF) instructions next state to use the following command line to deploy the software:
blg64100008xxen.exe BeCheckUpdateOption=3 BeCheckUpdateIsEnabled=0
Your instructions reflect installing a deployment package.
I am completely confused how to accomplish this across the network.
I spoke with Charles and recommended that his users run the installation manually
