How can I change this
I was use trial version of Staad.Pro Advance Edition in Staad.Pro CONNECT Edition Then Trial License is expired
I open Staad.pro connect edition They pop-up "Staad.pro Advance - Activation Status" Dialog
if I click "Activate" or "Close" They alway pop-up another "Staad.pro Advance - Activation Status" Dialog with Product Activation Wizard
Then I check "Select subscriber activating against a host(Bentley) SELECTserver" Click next
I put Server name and site activation key then click Next, Then I check sign in later and Next, Then Thailand, Next, And Finish
They tell "Your Product activation is now complete. You may use your product" Then Click Close
The another Product activation wizard dialog still open Then i Click close
They pop-up Dialog "Staad.Pro CONNECT Edition" with note "Trail/Valid license was not found or license has expired! Aborting...."
I click OK Then Program Close
How can I fix this ?
I have license of "Staad.Pro" product
I have also same problem like patiwat can you help me please ...
You have licenses for STAAD.Pro but not STAAD.Pro Advanced. Please perform the same steps I asked Patiwat to perform.
