IF I CHECK OUT A LICENSE IS THERE ANY CHARGE?
To whom it may concern,
Hi sorry I'm a bit confused regarding the terms of the billing, my License is STAAD Pro SELECT Subscription, for example i  would check out a License in the License management (License Checkout). Are there be any charges upon doing that?. I would just like to know because our accountant might ask questions if there would be any extra charges other than the charge of the STAAD Pro SELECT that we subscribe.
Manuel
  • No, when a license is checked out, usage is continuously logged against this machine until the license is checked in early or the specified checkout expiration date is reached. It is the equivalent of a user opening the product and using it for several days. Just be careful with license checkouts since they reduce the number of licenses available for sharing among users. If you own one license and the license is checked out on a machine, extra charges (i.e. term licensing usage) can occur if another person opens the product normally. To avoid unintentional charges, consider using a checkout-only workflow for all users, specifically the sections titled "A suggested workflow" and "Additional configuration steps for SELECT Open Access users."
    Answer Verified By: Manuel Jr. Gonzales
Reply
