Like many others I get the error below.
Uploading the logs now. Filename is ConnectionClientLogs.zip Interestingly enough I am not able to reproduce the error by using a web browser to connect to ims.bentley.com. Please help!
Hi Brian,
Please try resetting your Internet Explorer settings https://support.microsoft.com/en-us/help/17441/windows-internet-explorer-change-reset-settings
Tamicca SellarsMicroStation Product Manager
Nope. It's worth noting that I couldn't fully reset as corporate IT controls some of the internet settings.
We have discovered that a recent Windows Update has caused issues with the way that the CONNECTION Client communicates via Internet Explorer. We have an updated version of the CONNECTION Client 10.00.12.08 that is available in the Software Center that resolves the issue.
Please download and install CONNECTION Client version 10.00.12.08 to resolve your issue.
Bentley community is host to many problems and errors of the browsing. All the challenges of the trustmypaper review are remarked for further challenges. Opportunity is ensured for the mid paths for humans. The Bentley community is equipped for the middle of the ousts for all humans. the chances vital for the private items for the individuals.
You need to change the IP connection on the client-server. If you will connect to the webserver address after clearing the browser history, then the http://sites.gsu.edu/cpark37/2020/12/12/pros-and-cons-of-writing-tasks/ will open smoothly in the browser. The unzipped file is also another option to solve the error. It will also reduce the load on your web browser so you can open other web addresses as well.
