CONNECT Advisor - Expert - Unauthorized User
I have been trying to set up the use of the Expert Advisor - Using the help file, I followed the steps setting up roles and granting permission to the Expert Advisor section within the CONNECTION Centre / Project Team Management
The project within MicroStation has been setup as connected, I have full permissions, initially setup as Enterprise Roles, then tested as Project Roles, both times, when I select the Expert Advisor tab, I select the CONNECTED Project, I then receive the error 'Unauthorized User'
Could someone please other their Expert Advice
Cheers
Chris
Chris,
As described in the user guide
did you create two Enterprise roles , "EA Expert" and "EA User"
and give them necessary permissions
and in the Project management, assign the users the roles
then the users must be all set
if you can send me a screenshot of your
- Role Management
- Project Member management
I can point to what could be wrong
I initially didn't create two roles
I created the one Admin management role, with virtual everything selected
First as Enterprise role then transferred to the project role
Please follow the steps as mentioned in the user guide
the roles names have to be "EA User" and "EA Expert"
Answer Verified By: Chris Dixon
Ni Nazeer,
That did work, creating the accounts with the precise names given does allow access
Is a little strange that your not able to assign them to other roles and have that work, requires specific role names
Thanks for getting this to work
