is it possible (and how) to configure what langauge will be used in CONNECT Advisor GUI?
I have MicroStation CONNECT Edition Update 11, English version, installed; no other language pack is installed. From some reason CONNECT Advisor is started with Czech GUI, which is awfully bad. Surprisingly, I have also MicroStation V8i (SELECTseries 4) English installed and from V8i, CONNECT Advisor is started with English GUI.
With regards,
Jan
CONNECT Advisor uses the language of the consuming product it is launched from
if CA is launched from a Japanese MicroStation, CA would show Japanese UI
if CA is launched from a French MicroStation (or any other Bentley Product), CA would show French UI
if you see Czech GUI from Engish MicroStation, then this would be a defect.
CONNECT Advisor generates some diagnostic logs, that I can check to see what could be the issue
can you do the following
Answer Verified By: Jan Šlegr
Hi Nazeer,
thanks for the instruction, I will check the log, and when necessary, will send it to you, later this this week.
e-mail with zip file attached sent to your bentley.com address.
I checked the logs at it seems like CA is using the same language as the OS on some versions, and on some versions it uses the product language.
Bentley Standard is : use the OS language for UI.
thanks for the details.
Nazeer Hussain Shaikh said:it seems like CA is using the same language as the OS on some versions, and on some versions it uses the product language.
Which I hope will be classified as bug.
Nazeer Hussain Shaikh said:Bentley Standard is : use the OS language for UI.
With all respect, there is no such standard. I know Bentley produces a lot of software and I do not know all (but after 30 years, quite a lot of them) and I am not aware about any such product:
Extending situation I used in my older e-mail:
Maybe it's some internal Bentley standard, but today software standard even for open source voluntary projects is that when possible, OS language is used for the installation and alternatively the first start also, but can be freely configured later (sometimes even without any restart).
It's weird that what is implemented in many open source software by people cannot be done by Bentley as professional software company...
