is it possible to start CONNECT Advisor independently and not from MicroStation or other product?
I have not found how to do it, but it looks a bit weird to me, because Bentley have promoted and recommended Advisor as unified source of information ... which cannot be when heavy product like MicroStation has to be used as "Advisor launcher" and MicroStation license is consumed.
With regards,
Jan
CONNECT Advisor works in the context of a product, so that I can give recommendations and suggestions using the product in use.
We are coming up with the Web version of CA, that would be accessible via a webbrowser.
This CA would be available in the CONNECTION Center portal.
We are expecting to release this in a few weeks
Answer Verified By: Jan Šlegr
Hi Nazeer,
Nazeer Hussain Shaikh said:so that I can give recommendations and suggestions using the product in use.
It does not work too well in real life. Using local (and complicated) example, for Czech user English tips/videos are annoying, not only because language, but more because used workflows and standards are completely different. But it's a topic for another discussion.
Nazeer Hussain Shaikh said:We are coming up with the Web version of CA, that would be accessible via a webbrowser.
It sounds promissing :-)
