I am getting the following message when I open my Bentley View connect edition:
Requested help previously, but nothing seems to solve the problem. I can't find the send logs now feature as well. Can somebody help.
The application also shuts down after a short period.
Felicity De Hart, you appear to have a version of CONNECTION Client prior to 10.00.13.17 which included the LogCollector utility. If possible, please upgrade to the latest version. Otherwise, perform the following steps instead:
Chee Lin Koh, there was an issue with your Bentley login that has been addressed on our end. Please confirm whether the problem is resolved now.
Hi Jeremy
I upgraded and uploaded the log file - Log - 20190313.zip
There was an issue with your login that will require some changes on our end to resolve properly. I will contact you privately with a temporary solution in the interim.
Hi Jeremy, unfortunately, it is still not resolved. Is there anything else i can do?
