Has anyone tried applying 'User Alerts' within the Entitlement Management
Entitlement Management - User alert settings, unable to change acknowledgement.
I can apply a restriction, I tested setting the threshold to a count of 1, I wanted to check I was receiving the alert as an administrator
However I cannot change the user message to none, if I go to the pulldown nothing happens
Cheers
Chris
Yes it is still an issue. Worse that some customers still receive invoice retroactively when upgrading old products like PowerMap to Map if it is done while quarter is not ended as it now shows as overusage.
