A new and upgraded version of CONNECT Advisor version 10.01.00.179 has been released and is now available for download via the Bentley Downloads site.
This version is also available via the CONNECTION Client update service and you will receive a notification for update to this latest version.
Following changes that are included in this release
- Upgrade to latest Connection Client v10.00.15.012.
- Upgrade to latest Connect Licensing v11.00.03.011.
- Upgrade to .NET Framework 4.6.2
- Enable Search (Highlight) in the recommendation, contextual, offline viewing tabs.
- Critical security issue fixed.
- Defect fixes.
Hi Nazeer,
can you please provide information when the bug discussed in this discussion will be solved?
The new version still uses language defined by OS, not MicroStation. It means using English MicroStation in Czech Windows, Advisor GUI is in Czech, not in English.
The problem is that Advisor (similarly to the most of other Bentley products) localization is completely bad and a piece of crap (in fact, it's even worse, but such words are not allowed to use in the forum). Literaly every second term is translated wrongly, probably because it was translated using copy-paste to Google Translator, with no understanding of the product context.
Jan
Nazeer Hussain Shaikh said:This version is also available via the CONNECTION Client update service and you will receive a notification for update to this latest version.
When do we get the notification of this update. So far my CC hasn't notified me!
To be honest even if I get notified I won't be installing as it just overwrites all our custom configs. I have an ST open for this but to date no suitable answer received.
