and i try to login using connection client, the log is below
Starting Check...Checking service...Checking Network...Checking CONNECTION client...CC configured with Env 1Checking ULAS...User: it@xxx.xxxAccountId: User ID: 315BBA07-44C2-48C8-8F8E-2EDF9D78C6F8Failed to check ULAS: System.ArgumentNullException: 值不能為 null。參數名稱: String 於 System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) 於 System.Number.ParseInt64(String value, NumberStyles options, NumberFormatInfo numfmt) 於 HealthCheck.HealthViewModel.CheckUlas(CCLicenseClient ccApi, ServiceClientAPI lcApi)Checking Entitlement...Done.
could you help? thanks
The message you're getting on the Service Request Manager page is because you're account that you're using to sign in with is not linked to an organization.
For the CONNECTION Client issue please use the Bentley Log Collector to gather the logs. You can post them here in the discussion, or you can use the Secure File Upload instructions to upload your logs: https://communities.bentley.com/help/w/be_communities_help/7079/communities-secure-file-upload
Tamicca SellarsProduct Manager I
Hi, we got a same feedback from a user, their company got the same error, CC can be login, but can't retrieve the license, CC health check will got the same error as user posted here. Did we got a solutions for this ?
simon so said:Failed to check ULAS: System.ArgumentNullException: 值不能為 null。
The C# exception that is thrown when a null reference is passed to a method that does not accept it as a valid argument. An ArgumentNullException exception is thrown at run time in the following two major circumstances:
