I just installed a VPN. Connection Client seems to be not happy. Microstation Connect runs fine. CC runs right sometimes, sometimes it shows red X. I can log out, then log back in, cc is happy.
Are there known issues using CC with a VPN?
There are no know issues with logging into CONNECTION Client via VPN. You may wish to review the WIKI on CONNECTION Client to see the connectivity requirements -
CONNECTION Client FAQ
https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/36380/faq
If this is still an active issue for you, please submit a service request, or call directly.
I dumped the VPN software. Several issues made it not worth the trouble.
There could be issues if you pick a destination VPN server that is not in the same country as the servers listed in the link. Bentley does seem to use a CDN so that may complicate things. I've heard raves about ExpressVPN though not a customer of any at this moment.
Bill
