Hi
Unfortunately we do have a new customer which are running Bentley Map PowerView SS10 with the CONNECT Licensing. The product activates correctly, but they can only run in 13 minutes before they get an incorrect message, that says "Product is not activated and will exit in 2 minutes".
We do also have this issue with both Bentley Map PowerView SS3 and SS4 but with the old activation key system. I have prayed that this problem only was related to activation key, but it does not seem to be that.
I have uploaded logfiles with secure File upload.
I hope that somebody can help figuring out what this problem is caused.
Best Regards
Rune H. Christensen
Reseller
LIFA A/S
Hello Rune H. Christensen,
Please follow the steps given in below mentioned wiki link to activate the product:
https://communities.bentley.com/products/licensing/w/licensing__wiki/40262/how-to-activate-products-under-subscription-entitlement-service
Sheetal
Seems lic server is again down.
Hello Sheetal
Thanks for your answer. I have followed the steps for Option 1. The activation process is going fine and I can see "Allowed" in the access column. Also I can see that the "Expires" date is renewed every day, so the activation seems to go well. But still the user ran into the message with missing activation after 13 minutes. I have only seen that dialog in Bentley Map PowerView, not in other Bentley applications.
Rune
Hi Rune,
Please share the screenshot.
Hi Sheetal
Here is the screenshot of the entitlements.
Underneath you can see that under "Product Status", that OpenCities Map PowerView is missing.
