Can any body help me out to activated PowerGeopak SS10?
Previously we used PowerGeopak SS4, we were able to activated by putting Site Key and License server, but since we moved to SS10, there is no way to do this.
Can you help please?
Hello Bruce,
Please follow the steps given in below mentioned wiki link to activate the Product:
https://communities.bentley.com/products/licensing/w/licensing__wiki/40262/how-to-activate-products-under-subscription-entitlement-service
Sheetal
Good Morning Sheetal Bhegade,
Thanks for your respond,
I followed the steps, but i see the tab of Expiration date is soon to be expired.
How can we fix this?
Best regards,
By default all Connect Edition product shows 7 day expiry date and it checks user sign in on Connection Client everyday. So from current date you will see expiry date of 7 days.
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: Activated PowerGeopak SS10
Kindly follow the below mentioned steps :
log out the Connection ClientGo to Task manager, select Connection Client for windows, Bentley.licensing.service for windows and click on "End Task".Open "Run" and search for %localappdata%\bentleyDelete MySELECT.db fileGo to Licensing folder and delete LicenseService fileGo to activation wizard and try to activate the product
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.Flag this post as spam/abuse.
