hi,
good day. we are having issues with the product activation and we suspect that this is due to firewall/proxy server change. we are now using .pac file for our proxy server. can someone help me where i can configure the software to use the .pac file?
thanks,
It sounds like you are having issues with product activation due to a firewall/proxy server change, and now you are using a .pac file. I understand that you are looking for help in configuring the software to use the .pac file, and I would be happy to help. Firstly, you need to make sure that your software is compatible with the .pac file. Once you have confirmed that, you will need to download the .pac file and save it in a secure location. Then, you need to open the software, go to the settings, and select the .pac file. You may need to enter a few details from the .pac file, such as the IP address and port number. Once you have saved the settings, your software should be able to use the .pac file. If you are still having issues with the product activation, then I recommend changing your proxy provider. I use the ones from https://soax.com/premium-proxy-trial, and I don't have problems. Hope it helps!
Hi Pablito
PAC file is set via the Internet Options (Connections > LAN settings > Use automatic configuration script) and Bentley Licensing Tool needs to be configured to use system proxy settings.
Please note those options depend on your internal environment setup and need to be configured by your IT department
