Connection Client 10.00.19.27
When installing Bentley Connection Client via SCCM 2012 it is failing, I have tried a few different switches and options to no avail. I also used /layout to create an installation but the issue persists. If I run the same switches from an admin command prompt on a test PC the same installation command works. Please see the below options I have used and the SCCM logs from the install. I have installed previous clients without issue using the same method via SCCM.
So, the previous version I had installed via SCCM successfully was 10.00.18.25, using the following command line
"blg6410001825en.exe" /S InstallDesktopShortcut=0 NoStartPostInstall=1
Here are the methods I have tried with Connection Client 10.00.19.27
"blg6410001927en.exe" /S InstallDesktopShortcut=0 NoStartPostInstall=1
"blg6410001927en.exe" InstallDesktopShortcut=0 NoStartPostInstall=1 /q
"blg6410001927en.exe" InstallDesktopShortcut=0 /q
"blg6410001927en.exe" /q
And the same error resulted with " Process xxxx terminated with exitcode: 4294967295" and in Software Center "0xFFFFFFFF(-1)"
I also performed the layout with "blg6410001927en.exe" /layout choosing noui and no desktop shortcut the using the install files;
{316a7d44-0919-4912-a9e7-a0d67965485e}.lyt
NDP462-KB3151800-x86-x64-AllOS-ENU.exe
Setup_CONNECTIONClientx64_10.00.19.027.exe
In the distribution point and using just "Setup_CONNECTIONClientx64_10.00.19.027.exe" for the installation command with the following result;
"Process 15808 terminated with exitcode: 4294967295" in the AppEnforce.log
Though if I run the command via an elevated command prompt it works.
Please help. Is there an issue with this installer?
Regards, Simon.
