Please can Bentley advise what happens to non-select node locked V8i licenses after January?
In the past they need to be renewed annually. Will this process still work and if not what will be the alternative?
Hi Duncan Macdonald,When you read the article further, there is this:"Your Products need to connect SELECTserver OnLine in order to authenticate and check-out your license. Once the check-out is successful, you will not need to keep a connection to SELECTserver OnLine.
Thanks Mika. That's what happens now with a node locked licence. If the process is staying the same then that's fine.
