I have a computer with Bentley Connection client but no one can login. It is just stuck on "Working...".
I have tried reinstalling the program to latest version. I have also tried this command: "C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\Bentley.Connect.Client.exe" - noautosso
And I have tried deleting .db files in the user profile, but nothing works. Still just this message. Any idea of how to get this back on track? It has worked before on this computer.
here you go https://status.bentley.com/
If you are unable to sign in to the CONNECTIONClient, please install the 11.00.01.109 version from Software Downloads. https://softwaredownloads.bentley.com/en/ProductDetails/1805?packageid=25583 You will need to filter the versions to get it. We are working on resolving why the users who see this issue are running 11.00.02.XX
I would love to download a working version from there but it says:"You do not have access to Software Downloads. "
Thanks - downgrading to 11.00.01.109 helped ...now the login works and I'm able to do my work again :-)But Bentley, please fix this bug a.s.a.p. ...it is an embarrassing mistake especially because we are forced to use the CONNECTION client.Regards Anders
I am having the same problem today.
the same right now.
I have installed CC 11.00.01.109 and it is perfect.
In fact, this last Friday my ORD freezes when I tried to open "template drop" .... maybe when CE started to fail.
