First time using overlay/stripping component in my template.
The properties I used are as followed:
Top option: Follow Surface
Bot option: Follow Surface
Surface: <Active>
Stripping Component: Toggled On
It is all fun and game until I get my earthwork quantities. I am only getting cut and not fill. When I switch off my overlay/stripping component, the fill will show up. Is it the way I have it set up or is this a known problem? I am running on ss10. I know we're transitioning to ORD Connect (idk if this problem persists) but I just want a solution to this. Probably spent way too much time testing out different ways.
