Connection Client support dates
Related to Connection Client release notes, can I request there be a End of Life dates associated to Connect Client versions?  I know Bentley is working on this 11.00.02.xxx issues with Microsoft, but we have had numerous times with a older Connection Client has a broken 'page' in the client, or a broken link because Bentley changed server locations.  This shows release notes, but not updated info, like in the known broken 11.00.02.xxx versions, or 'no longer supported' example <10.00.19.xx
(communities.bentley.com/.../release-notes)
I want to make sure my coworkers stay to at least the minimum version to eliminate any breakage in their Connect sign in and keep them up and running.
  • I also need this information for multiple reasons. The life cycle of CC should be published to include the sunset phase without any surprises. I did check the support matrix and CC isn't present or I'm "blind."
    One of the reasons I need this is we cannot tolerate production outages. We have about 500 users that use Bentley products. We cannot and do not have CC do upgrades. The CC v 11x debacle is a prime example. The auth token authorizing the machine may allow the user to run, but it doesn't stop the egregious nagging to sign in.
    Bill
Reply
    Bill
