Is there a way to block another computer from opening MicroStation if another session is opened on another pc? This would be so helpful with the chance of overage uses
"Bit thin-skinned, don't you think?" Goes with the times
Kirk
I Wish Cadland was Reality
Glenn, I have that set to one and I get false usage warning messages.
Even worse you can get false overage for blocked product(owning Microstation Powerdraft but trying to run Microstation by mistake) as alert for blocked product is not counted as alert and get overusage for 0 minutes. To this date have not received answer if it is finally resolved.
Unfortunately blocking is not implemented as it would interfere with user experience in case of urgent task.
I don't recall hearing anyone getting a false usage warning message before when I supported this application. I would log a Service Request and provide the workflow, it seems as thought something has changed.
Multiple ST are logged but they are dealt case by case not possible to log as a global issue.
ST7001130291 for example
