Is there a way to block another computer from opening MicroStation if another session is opened on another pc? This would be so helpful with the chance of overage uses
Thanks, I looked at your SR number (which was for Context Capture) and the issue was addressed with a new version 10.17.00.39.
No it was not addressed you fell into the same logical trap. It was addressed for this specific scenario but it should have not generated invoice in the first place. How is 0 minutes overusage even possible for blocked product? Is it addressed?
I am not with the Entitlement Management team, but I will make sure they are aware that there are other examples of this happening. I thought that there was something specific to the CONNECTION Client, but from the SR you provided, it appears that this is in the product/entitlement.
It was just an example that block doesn't work as expected. I had more numbers which could provide later this week. Maybe this was related to CONNECTION client but never received any explanation of the cause. The alert shows correctly that no entitlements for this product with option to close the program but it generated usage in the background while reading this same alert.
I appreciate the input. I will take other examples when you get a chance. Thanks
