Is there a way to block another computer from opening MicroStation if another session is opened on another pc? This would be so helpful with the chance of overage uses
Here is a simple solution. If you have Microstation running on PC number 2 and you want to run it on Pc #1 you can choose the pc .you want to allow to have access and take control can do it why can't Bentley?
Kirk
I Wish Cadland was Reality
SR#7001179073 also
Hello Oto, I've asked a Senior Entitlement Management Analyst to further review current SR 7001255125 and contact you as soon as possible.
No need to contact all these SR are solved on case-by-case escalated and reviewed multiple times but there is no answer if underlying issue is resolved as it shouldn't have generated invoice in first place as there was a block for this product
I have lost SR number but there was also dispute case DC210843.
