Trying to log in and getting:
I would add that this is stopping me working and I have deadlines to meet this morning. Clients are waiting for drawings.
Hello Stuart,
Please check if a user is registered in the Active directory of your organization. Once the user is added in AD, they should be able to login.
Sheetal Bhegade
This seems to be a wider issue - several clients are not able to sign into the IMS server this morning.
Yes we are as far as I know. Was certainly working OK last week so not sure what has changed. Note that all Bentley users can't log in and are getting the same message.
What has AD got to do with logging in to use MicroStation?
Hello Robert,
I tried to login on to my machine and everything seems working fine. If you are getting any issues then we need CONNECTION Client logs to investigate the error.
You can also raise the service request from here: https://apps.bentley.com/srmanager/ProductSupport
