After updating my Bentley connect client i get the following:
here is the result of the connect license health check tool.
Starting Check...Checking ServiceChecking CONNECTION client...Checking Windows file permissionsFolder Permissions: TrueServer mode is offChecking NetworkGetting domains from BUDDI.Pinging domains.Checking ULAS...Skipping ULAS check - Not signed into CCChecking Entitlement...Skipping Entitlement check - Not signed into CCDone
it has happened since i updated the connect client yesterday.
i have put in proxy servers and removed them as well.
i cannot even sign into the connect client
Hello Ruan,
Please refer wiki https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/w/wiki/54520/connection-client-says-working and follow the resolution steps suggested.
Sheetal Bhegade
Answer Verified By: Ruan Wiggett
thank you so much Sheetal Bhegade
if anyone runs into the same problem and are unsure on how delete edge here is the command:
run CMD as Administrator
type in the following commands:
cd\
cd Program Files (x86)
cd Microsoft
cd Edge
cd Application
the path should look like this "C:\Program Files (x86)\Microsoft\Edge\Application"
del msedge.exe
press "Y" to confirm if prompted
quit the Bentley tray icon and it should be operational
thank you again Sheetal Bhegade
