Hi All.
I hope I can get an answer to my questions here.
Like most of us, our client requires us to use older legacy versions of certain Bentley products. I'm trying to identify what's next for the older legacy products?Is there anything else I need to do as an Admin to ensure these applications remain licensed?The documentation makes reference to a report called SelectServer Usage, but this tile is not visible under Usage Analytics?
Will these older products stop working?
Hi Marcus,
Your comment and your title seem like they match.
Some of your answers may be found in:https://communities.bentley.com/products/microstation/f/microstation-forum/221547/will-i-still-be-able-to-activate-and-use-bentley-microstation-v8i-after-january-1-2022
For the Select usage report, go to Subscription Analytics -- Daily Usage by Machine and select "Server Type" = "Hosted". The SES server types are the "Connect" style licensing, and the Hosted is the SelectServer style licensing.
--Robert
Hi Marcus
No, the legacy V8i versions (SS10 and earlier) will not stop working and you can continue to use them - starting from January 1st, 2022 it is the technical support that will be discontinued and the support will be provided only for licence-related issues. See:
Support for V8i SELECTseries 10 applications after December 31st, 2021
Administrators manage ALL versions (CONNECT Editions and legacy) in the Entitlement/License Management portal.
Entitlement Management Overview
Announcement: Deprecation of SELECTserver import of restricted applications and checkout restrictions on December 15th, 2021
Hope this helps
Answer Verified By: Jacek Majda
