We have been facing major problems with Connection Client recently. The client application won't start properly. It will launch up to 50 instances and reserves 100% of the CPU resources.
Furthermore, Microstation, which is our main design tool does not work either because Connection Client doesn't allow it to launch. This problem has occured in five workstations so far. We have 20 workstations running Microstation and this kind of faulty program will cause some serious trouble if it will hang all workstations...
Removing and re-installing Connection Client & Bentley apps didn't help. I managed to get one computer up and running by re-installing the Win 10 OS and all applications but it would be a total nightmare to re-install every single computer.
Is there some solution for fixing the problem?
Yrjö Ala-Heikkilä
All depends what MS decides with their InTune product. Nobody here has a choice. I don't want to even attempt to remove the hotfix from hundreds of machines either.
Bill
These sorts of issues have come up from time to time over the years. They always seem to work out after a bit of Time passes.
KB5013942 is a cumulative update which also incorporates KB5011831. Either update may cause this problem to manifest with CONNECTION Client. If the problem surfaces, please temporarily either of these updates if present for now. We are still investigating internally.
We had the same issue yesterday with the KB5013842 update. I had to go to each workstation (15) and uninstall the update. We also paused the windows updates for 7 days. And we will have to keep doing this until the issue is resolved. I had to go to 2 different Bentley tech support people until someone was willing to help yesterday. The first guy didn't know what the problem was and did not offer any support. He didn't even start a service ticket. The 2nd person knew exactly what to do and created a service ticket. Thank goodness I called back. But we basically figured it out when all of the computers had this windows update. It was a pain to deal with, but we got it figured out. Our company was basically shut down for 3/4 of the day. The strange this is one of our computers had no issue with connection client and installed that update.
After some research yesterday, i put together a powershell script that i was able to push out to my users' machines. It hides KB5013842 so that they are unable to install it. See script below:
Install-PackageProvider -Name NuGet -MinimumVersion 2.8.5.201 -ForceInstall-Module PSWindowsUpdate -force -confirm:$falseGet-WindowsUpdateHide-WindowsUpdate -KBArticleID KB5013942 -confirm:$false
