So I saw this thread:
https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/f/forum/229320/what-is-going-on-with-the-connection-client-is-there-a-conflict-with-a-recent-windows10-update-or-what
It appears that an optional update caused Bentley to use 100% of a user's CPU. Fixed by uninstalling and avoiding that optional update. However, a new update, KB5013942, is not optional and appears to contain the same things from the optional update that caused Bentley to brick computers.
This seems like a MASSIVE issue. I think the update just came out yesterday or today but it has the potential to leave every computer on our network crippled if our users unsuspectingly install this Windows update. Is Bentley working on a solution to this? Seems huge. The issue isn't Windows updates. They aren't going to revise their updates to be compatible with Bentley Connect Client. I'm assuming the client will need to be repaired.
FYI - For anyone that is seeing this issue, it is now being tracked via Bentley's status dashboard: https://status.bentley.com/ There is an option to get notifications pushed to you for specific applications, so you can sign up if you wish to get automatic updates on this topic. Here is the first post:
Service: CONNECTION Client Status: Good Notes: We've received reports of a Windows Update affecting the operation of CONNECTION Client. We are actively looking in to the issue and will provide regular updates until the issue is resolved. Please see Issue with Windows Update affecting CONNECTION Client for more details.
Thank you for the info Glenn.
Thank you for your offer above.
The latest update from the status dashboard. I would highly recommend you sign up to get these updates.
There is important information about a service you are following
May 23 Update: Several of the users we've worked with have reported that they are using SofTrack software metering. Integrity Software has announced "We have discovered that Microsoft's recent Windows 10 update "KB5011831" is causing some applications (both 32 and 64bit) to not fully startup and instead use high amounts of CPU time." and that they have a fix available. If you are experiencing this issue and are using this 3rd party software, please try applying their fix.
Thank you, I received the status update and I do use SofTrack software. I will report back with a resolution shortly.
