So I saw this thread:
https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/f/forum/229320/what-is-going-on-with-the-connection-client-is-there-a-conflict-with-a-recent-windows10-update-or-what
It appears that an optional update caused Bentley to use 100% of a user's CPU. Fixed by uninstalling and avoiding that optional update. However, a new update, KB5013942, is not optional and appears to contain the same things from the optional update that caused Bentley to brick computers.
This seems like a MASSIVE issue. I think the update just came out yesterday or today but it has the potential to leave every computer on our network crippled if our users unsuspectingly install this Windows update. Is Bentley working on a solution to this? Seems huge. The issue isn't Windows updates. They aren't going to revise their updates to be compatible with Bentley Connect Client. I'm assuming the client will need to be repaired.
Thanks, that would be great to get some confirmation either way.
I uninstalled the SofTrack agent, and installed KB5011381 / KB5013942. I am now able to run the CONNECTION Client. I am also able to use other products that were seemingly broken by KB5011381 / KB5013942.
This will take some work to remedy... still better than even one accidental Term License use though...
thanks for posting an update so that this will help other users.
I'm still getting to all the comments and may find some satisfaction here, but 'if Wndows Updates cause problems, make sure you're running Windows Updates' is not a response that adds to the conversation in my opinion. I have machines that are fresh installs with all updates from Microsoft run that have this problem. This was one of many examples of 'here's something that may help, so I'm going to imply that you're doing something terrible and causing this yourself'.It's reasonable to expect we won't have all the latest security fixes if we don't run updates, but updates have caused vast and expensive problems countless times. It's not reasonable to demand everyone always be fully up to date. Even if it were, in this case, it does not solve the problem. I have now probably dozens of Windows Updates that are marked for uninstall in WSUS because I've been able to confirm they leave my users totally non-functional. Today is the first day I've had this problem where Microsoft 100% will not allow me to remove the update. This is a Microsoft problem, possibly with some share of blame for Bentley. This is not something PL caused.
