Is there any guidance on home use licensing (particularly around Maxsurf)? one of the team would like to do some non business related work on a personal machine.
Hi Jonathan
Licences can be used the same way at work/office as well as at home - there is no difference. You can even use the licence at work AND at home. The licence is activated by recognising the user, who signs in to the CONNECTION Client, hence the only requirement is users need to be associated with the account and have entitlements to use the licence.
How to activate products under Subscription Entitlement Service
Thanks Jacek,
So how does a license get use both at work and home?
Wouldn't the system just charge you for two licenses?
How does it differentiate?
It will of course record usage from two different machines. But you can use the licence at home the same way and whether or not you are charged for using an additional licence - it will depend on how many licences you own AND if the licences are used at the same time.
