When I run the 'Connect license Client Health Check' the following errors are identified:
Any suggestions for how to resolve? This is preventing use of this license.
I've copied the health check results below:
Starting Check...
Checking Service
Checking CONNECTION client...
Checking Windows file permissions
Folder Permissions: True
Server mode is off
Checking Network
Unable to connect to domain https://connect-wsg20.bentley.com: System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'connect-wsg20.bentley.com'
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsyncResult ar)
--- End of inner exception stack trace ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Net.Http.HttpClient.<FinishSendAsync>d__58.MoveNext()
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at HealthCheck.HealthViewModel.CheckDomains()
---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'connect-wsg20.bentley.com'
at System.Net.Http.HttpClient.<FinishSendAsync>d__58.MoveNext()<---
CC configured with Env 1
Checking ULAS...
User:
AccountId:
User ID:
Usage Request ID:
Usage Message: Accepted
Checking Entitlement...
Failed to check entitlement: System.AggregateException: One or more errors occurred. ---> System.Threading.Tasks.TaskCanceledException: A task was canceled.
at HealthCheck.HealthViewModel.CheckEntitlement(CCLicenseClient api)
---> (Inner Exception #0) System.Threading.Tasks.TaskCanceledException: A task was canceled.<---
Done
Hello IT support,
There was global outage yesterday with Entitlement Management. The issue is fixed now and users should be able use the products now.
We’re sorry for the inconvenience caused due to this outage. We appreciate your patience. Thank you for your support.
Regards,Abhishek
It is the same situation now?
Please help me.
Starting Check...Checking ServiceChecking CONNECTION client...Checking Windows file permissionsFolder Permissions: TrueServer mode is offChecking NetworkGetting domains from BUDDI.Pinging domains.Failed network request: StatusCode: 403, ReasonPhrase: 'Forbidden', Version: 1.1, Content: System.Net.Http.StreamContent, Headers:{ Transfer-Encoding: chunked Connection: close Cross-Origin-Embedder-Policy: require-corp Cross-Origin-Opener-Policy: same-origin Cross-Origin-Resource-Policy: same-origin Permissions-Policy: accelerometer=(),autoplay=(),camera=(),clipboard-read=(),clipboard-write=(),fullscreen=(),geolocation=(),gyroscope=(),hid=(),interest-cohort=(),magnetometer=(),microphone=(),payment=(),publickey-credentials-get=(),screen-wake-lock=(),serial=(),sync-xhr=(),usb=() Referrer-Policy: same-origin X-Frame-Options: SAMEORIGIN cf-mitigated: challenge CF-RAY: 7c8cf4123ab2788b-VIE alt-svc: h3=":443"; ma=86400, h3-29=":443"; ma=86400 Cache-Control: no-store, must-revalidate, no-cache, max-age=0, private, post-check=0, pre-check=0 Date: Wed, 17 May 2023 15:39:29 GMT Server: cloudflare Content-Type: text/html; charset=UTF-8 Expires: Thu, 01 Jan 1970 00:00:01 GMT}Checking ULAS...Skipping ULAS check - Not signed into CCChecking Entitlement...Skipping Entitlement check - Not signed into CCDone
Hello Ilinca,
What is the error you're getting on the CONNECTION client? Can you please share the screenshot for the same?
Firstly, thank you for your prompt message.
I am unable to connect and I receive a message instructing me to run a health check.
Is it possible that this issue is due to having a duplicate account/profile with the same personal information?
Can Bentley remove the old account/profile if it is this situation?
Best regards,
Phd Eng Costin I
Thank you for sharing the screenshot. Please follow the troubleshooting given in this WIKI to resolve the issue.Regards,Abhishek
Abhishek Paranjape said:ubl
I have same issue now and trouble shooting methods mentioned in WIKI doesnt help.
