Select Server Activation
I'm running Select Server 8.11.1.64 on my network server, Windows Server 2003 and made a bit of a boo boo.
 between powerfailures and being really busy I forgot to run the Select Server again and subsequintly didn't send usage logs from Select server.  I though something was abit wierd and when I looked now, everything seems to be locked on the Select Server.  There is only two option I can click on, the one is Manage Services and the other is Transmit Usage Logs.
When I try to show Manage Services to restart Select Server al I get is in red letter when last I've send a log.  When I go to Transmit Usage logs, it opens up, but doesn't allow me to click on any icons or send any logs, I cannot create a file to send and it also tells me that No Records were found.
 This is obviously a mistake on my part, but can anyone guide me as to how to get all of this up and running again?  Uninstall and Re-install select server maybe?
Parents Reply Children
