Gents,
There any way that I can gett access into Select Server application (living in the sever) from my PC, in order to check the licences status and get reports on it.
Thnaks in advance
Cristian
Hi Christian,
Do you have SELECTserver installed onsite or are you utilizing a Bentley Hosted SELECTserver?
Hi Elisabeth,
We have a Select Server intalled onsite.
There any way that I can get access into the server from my desk...???
Thanks in advance
Criss
try this
http://SERVER NAME/bss/admin/default.aspx
replace SERVER NAME with your server name. I have this on my desktop.
Thanks Brian! That is exactly my answer.
Chriss, If you are still not able to access your SELECTserver then I would suggest calling into technical support and logging a ticket for further detailed help.
I follow the Brian tip...but does not work for me...!!!
You mention there a chance to open a ticket on it....
How I do...??
Kind Regards
You can log a Service Ticket through www.bentley.com/serviceticketmanager
Phil.
Thank you very much...!!!
Best Regards,
