Sir,
How can the license of staad pro can be return & re-installed, I want to format the hard disk due to some problems.
Can u help me as sson as possible....
Hello Gokul,
There is a technote on how to check in/out a license for XM or higher licenses:
communities.bentley.com/.../6013.aspx
Adam
Answer Verified By: Elisabeth Jaouad
Unless you are running disconnected from the server or you are non-select you should not need to checkout a license directly. If you have a connection to the SELECTserver you should just need configure the license by running the activation Wizard.
communities.bentley.com/.../how-do-i-activate-my-bentley-software.aspx
Before removing Staad, with internet access, goto License Management Tool
Inside it see in the lowerpart the entrance for Staad.pro and a Design Code.
Select each one separatelly and click on Checkin to "return" the license to the server
I attached a document that I have. Even thought is in Portuguese, the images will help.
See thread below
