I am attempting to upgrade Select Server to version 9. I installed according to the notes and when i tried to access the License Mangement Tool, i recived this error. Pelase see attchment. What is my next step to troubleshoot this issue?
So i started over with a fresh SQL install along with the Select Server Install. Now I'm stuck with a "Failed to retrieve a list of available licenses" Any suggestions?
This is the error I get when I try to use the activation Wizard
The error message indicates that your deployed SELECTserver is being reached, but your site activation key is not recognized. Please ensure that no spaces have been appended to the end of your key. If no spaces are present, please verify that you are entering the site activation key, not the server activation key, in the Product Activation Wizard.
Also, can you confirm that you are able to locate and access your SELECTServer administration page?
I am going back to the first error message. If you run the SELECTserver Database Setup (with right click Run As Administrator because of Windows UAC) does it say in the dialog
“The selected database is configured to support the Bentley SELECTserver schema required by this install.” , or something else? I am guessing this might be the problem. what does it say there under the Status tab?
