License "As Expired Error (No Server access to the internet)
Posted for the user:
select server license has expired - please renew. due to company policies not able to retrieve license directly from bentley
  • The link below is to the License As Expired wiki page on how to address the issue.
    communities.bentley.com/.../3281.aspx
    Becaue there is no internet connection the manual process must be adopted.
    MANUALLY:
    To manually import the license, you need to contact Bentley SELECTsupport (Administration and Activation) for a new XML license file. Once this license file is received choose the Import Server License link found on the left hand side of the Administration Site under License Management. Once you are inside the link, verify that the Serial Number and Activation Key (which is the Server Activation Key in this case) is correct, browse to where you have saved the XML License File, and press OK.
    The page will process and a new line should appear with a (+) at the beginning. This is the new license, and will need to be accepted for it is applied. To accept this license scroll to the right and in the upper right hand side of the screen there is an Accept button. Selecting the Accept button will update your License and the
    message will go away. It may still be necessary to complete the “electronic” steps. The overall issue is that at times the operating systems stores old information and it taks a little effort to get the OS to let go of the cached information.
    Answer Verified By: James White
