User is having the query as listed below,Staad.pro has been successfully activated and runs in fully functional mode still in the activation staus why does it displays it will expire in 5 days.
The suggested method of resolving this issue is by following the below technote:
communities.bentley.com/.../3384.aspx
The Activation Status window of the License Management Tool is useful for quickly determining the license status of Bentley products that utilize "trust licensing." Trust licensing products periodically report to the license server as they are used. Because such products must report to the server at least every 30 days, the Activation Status quickly shows how much time remains. RAM, STAAD, and AutoPIPE products, however, utiliize licenses differently. Licenses are temporarily locked to a workstation each time such a product is used. Consequently, the activation status for these products will appear as a trial period when not in use. The activation status for RAM, STAAD, and AutoPIPE products can be safely ignored. The products will display licensing errors when opened if a license-related problem exists.
Answer Verified By: Abhishek Paranjape
Tamicca SellarsProduct Manager I
Mam under license management it shows std different design codes with status as trial expires in 5 days should I ignore it coz I'm having problem in designing using indian code as it displays licence does not support indian design
It looks like you are using an old version of STAAD.Pro. Please create a service request.
