User upgraded to SELECTserver 9 Gateway service and need assistance to configure the applications to use with the new Gateway service.
The client machine, running Pre-XM applications, talks to the SELECTserver using a pointer file from the client workstation via the SELECTserver Gateway service/server.
A pointer license file is a basic notepad text file with a .lic extension which is saved in the licensing directory on the client computer.
For a list of license file names and default licensing directories for each product can be found on BE Communities at the following link:
http://communities.bentley.com/products/licensing/w/licensing__wiki/2668.aspx
If a .lic file does not exist, one must be created. For detail instructions on setting up the pointer file, please refer to the following link:
http://communities.bentley.com/products/licensing/w/licensing__wiki/3574.aspx
Once the license file is configured in place, launch the product and it should start.
Answer Verified By: Nicole Thomas
Tamicca SellarsProduct Manager I
