What will be the Product Installation Type
Can anyone elaborate, about the installation type of product activation wizard.
Mahbub
    Mahbub
    Unknown said:
    Installation type of product activation wizard
    It's not clear what you mean.  Perhaps a screenshot would help illustrate your question.
    The answer is in the details. In general all contact to support should have some basic information. When it comes to SELECTServer I'd like to see the following information.
    1) Exact version number of SELECTserver installed.
    2) Server or workstation operating system? Is it 32 or 64 bit?
    3) What error are you seeing on the server (a screen capture would be helpful) When the admin page first opens what is displayed?
    4) What error are you seeing on the client “ if applicable” (a screen capture would be helpful)
    5) Zipped copy of the “C:\Program Files\Bentley\SELECTServer\Logs” directory (or the root directory of where you installed the application
    6)  Copy of your serial number and activation key  (Never post your activation keys in a forum. There are directions for appropriate secure communications)
    Some variation of this information should be provided for specific clients when the questions is concerning product activation.
    Please provided some detailed information including a capture of the specific issue in question.
    James
    Regards, Jon Summers
    LA Solutions
  • Hi,
    I want to know, which type is for which user? Please see the image below.
  • Hi,
    1. Option “SELECT subscriber activating against a hosted (Bentley) SELECT Server” is for SELECT users activating against SELECTserver Online. This should be chosen if your licenses are held on server Hosted by Bentley. This way your applications connect directly to a Bentley Hosted server via the internet using the server name: selectserver.bentley.com.
    2. Option "SELECT subscriber with a deployed (local) SELECT server” - for user which has a SELECTserver installed locally or activates a home use license. This way applications connect to user's locally installed server using his local server name.
    3. “NON-SELECT or Node locked user” – option is for user which doesn’t have a SELECT agreement (non-select) or activates node lock (version and machine specific) licenses. Default server name: ProductActivation.bentley.com.
    4. “Evaluation Only – No license information” – should be chosen when activating unlicensed and in trial mode (evaluation mode) software.
    For detailed information about activating your product please see the article on BE communities: http://communities.bentley.com/products/licensing/w/licensing__wiki/2772.aspx
    Laura
    Answer Verified By: Marouf Khan
