Today I have the Select Server 8 installed and running on the server with Windows Server 2003 and SQL2000.
I have to make a Select Server migration to another server and I have some problem.
I am trying to install the Select Server 9 on the server with Windows Server 2008 X 64 and SQL 2008, after installing, the services Bentley Select Server and Bentley Select Server Gateway does not start, when I try to manually start the error occurs: Error 1067: The process terminated unexpectedly and the Select Server V8i Administration Site not start.
Does anyone have this same problem? Could you please help me?
Thank you
Leonardo
The following may be of help http://communities.bentley.com/products/licensing/f/275813/p/91700/290421.aspx#290421
"Community Not Found
The requested Community cannot be found."
Which Community can't be found? Or are you speaking about the link above, which I've just tried and was able to access.
Glenn
Community not found for me either.
I also can't access given link. There are some access restrictions.
