Activation issues with RAM Structural System 14.06.00, RAM Concept 05.01.00, and AutoPIPE 09.06.00
Users are reporting activation issues with the new RAM Structural System 14.06.00, RAM Concept 05.01.00, and AutoPIPE 09.06.00. Trial period messages continue to appear even after proceeding through the Product Activation Wizard. Normally, these messages cease once the activation process is complete.
The cause of the problem has been identified on Bentley's end. A license configuration setting is preventing workstations from reporting usage for these products, causing the activation process to fail. A resolution is being formulated and will be implemented as soon as possible.
Until a resolution is implemented on Bentley's end, please click the Try button when prompted for activation as a workaround. This forum thread will be updated once a resolution has been implemented.
Parents Reply
  • I have received reports from a few users with deployed SELECTservers who are still encountering activation issues. In such cases, I recommend generating a license debug log. With error logging enabled, attempt to activate the product. Then open the log file and do a search for "-15008". If this code is found, SELECTserver may be utilizing some old cached data. Restarting Internet Information Services (IIS) on the server should correct the problem. A system administrator can accomplish this by executing the following command from a command prompt on the server:
    iisreset
