Our local select server was on server "A". We have set up a new server "B" because "A" will be decommissioned.
We realize that we can go to each client machine and manually run the Product Activation tool and change the server name from "A" to "B", but we have dozens of client machines with a variety of products to configure.
Network licensed Autodesk products respond to a Windows environment variable (which of course we can set using Group Policy).....SO....is there some similar way to remotely change the SelectServer to which all of our client machines point without having to physically visit each machine?
TIA
There certainly is! Please refer to the following news article which describes how to configure license settings via Windows group policy or a command-line licensing utility included with Bentley products.
Answer Verified By: Tyler Q - Bentley
Thank you for the quick reply. Got it working!
