Can anyone explain this? The service is running but Connection client fails update telling me it is not started.
Really guys, if you are going to force us to use this client app, you've got to do a better job of making it work well in an unobtrusive manner.
Start or Restart BITS Service Windows 10. The steps include:
This will likely Restart the BITS service and fix in case the service is stuck simply because of any reason.
In case the service doesn’t start then double-click on it
If still the same issue persists you can take help of this guide on how to fix background intelligent transfer service (bits) to solve the issue. You can do it either via troubleshooter or by using System File Checker (Sfc) and DISM or either by manual update
