Just upgraded to MS CONNECT update 11 via CONNECTION client updates and now get this error. 'Unable to start 'MicroStation'. Licensing service failed with error code -1. ..."
This is a Windows 7 system, MS CONNECT update 8 was working fine. V8i works fine on this system as well.
I tried uninstalling and re-installing MS CONNECT update 11 - still same error.
I have MS CONNECT update 11 working fine on another system - that system is a Windows 10 system though.
The issues seems to have been have happened when CONNECTION Cleint upgraded MS CONNECT. I have CONNECTION Client 10.00.12.08.
Any help?
Hi Tanya,
This is a known issue. We'll be pushing a fix in the next release of the CONNECTION Client. Check your private messages. I'm sending you some information
Tamicca SellarsMicroStation Product Manager
Answer Verified By: tonori
I have same error.
I started MicroStation 'as administrator' and this worked, could have been a fluke tho.
The community is badly indebted by the instruments and all shows for the field. Formation of the past and best biography writers is issued for the challenges for all offers. The manner is piled for the host of the true value for the vernation for all goals.
Hi Dear,
Have you solved the issue? Mine is actually getting same error while starting the Openroads Designer 2021. Any chance to get an advice, please.
