Connection client v. 10.0.17.10 does not minimize on login, even though the preferences are set to do so - is this an known issue, or any workaroud? It's rather obtrusive.
Can you tell me if you're setting the preference through the client or registry key? If you're setting it locally you can rename MySELECT.db in %localappdata%\Bentley\ to MySELECT.old then start the CONNECTION Client and select the preference again to reset it.
Tamicca SellarsMicroStation Product Manager
Setting the preference locally through the preferences menu in the applet, and I tried renaming the .db to no avail
