Downloaded and installed connection client 10.0.18.25. Client not loading on startup or manually (i.e. no login popup). rebooted, repaired, re-installed, etc.... no luck. any ideas??
That is odd. If set to automatically sign in and minimize, you will see nothing except the little icon in the tray.
Windows Task Manager Startup tab should look something like this-
Thanks. Seemed that I had to select "run as administrator" to get it to launch.
